Problems After Cam/Intake Install Please Help
Old 04-06-2005, 11:16 PM
00Formula's Avatar
Default Problems After Cam/Intake Install Please Help
I just finished puting a 224/228 .578 112 cam, Ls6 Intake and LTs on my friends 99 TA and I am having some difficulties. The car has not been tuned yet but it has a noticlble miss at rpms below 2000 and struggles to idle. When driving above 2000 rpm its seems to smoothen out but when you put the clutch in it dies everytime. I have checked every plug and wire, removed the intake once to make sure it was sealed and everything was plugged in, and it still did the same thing. I have checked over everything to the best of my knolledge and Im stumped at this point. Any suggestions are greatly appreciated. Thank you in advance.
Old 04-07-2005, 12:41 AM
Predator's Avatar
It sounds like you need to tune the idle. The cam causes a false lean reading causing the pcm to dump too much fuel. A good place to start is try scaling the VE table x60, 80, and 90% at 1200 rpms and under.
Old 04-07-2005, 03:28 AM
DaddySS's Avatar
You need to start by finding the miss. Have you pulled the wires one by one to identify which cylinder has the miss?
Old 04-07-2005, 10:06 AM
00Formula's Avatar
I have not tried that yet. Would it be possible that it is missing on random cylinders and not just one? Thank you for the suggestions.
Old 04-07-2005, 10:51 AM
Cal
Cal's Avatar
You always get some idle and low rpm missfire with a big cam. Nothing can be done about that, other than program the PCM to ignore it.
Old 04-07-2005, 10:54 AM
MikeG's Avatar
You changed alot of stuff on the car at once. The computer is freaking out. A tune will most likely fix everything.
Old 04-07-2005, 11:47 AM
hourang's Avatar
what codes is it throwing? i ran about the same cam with a 111lsa, ls6 intake, and race longtubes no cats and it ran prefectly fine (even with a crap load of codes thrown) until my o2 sensor wire dragged on the ground then it ran like crap. its got to be something like a vacuum leak or something not plugged in all the way, etc.
Old 04-07-2005, 12:03 PM
00Formula's Avatar
What all areas could i check for a vaccum leak? It sounds like thats what it is but im not sure what else to check......I pulled the intake off once already and to my knolledge everything looked ok but i could be wrong.
Old 04-07-2005, 12:05 PM
oange ss's Avatar
pcv area
ls15244's Avatar
tune it
Old 04-07-2005, 03:04 PM
SlpLS1's Avatar
quit being cheap. just tune it! that will allivate 1 problem. then go from there.
Old 04-07-2005, 03:14 PM
LS1Maniac's Avatar
Sounds like a normal cam install to me.
Old 04-07-2005, 07:12 PM
00Formula's Avatar
How will a tune all of a sudden get rid of a cylinder missfire? I know it willl idle much better and dial in the a/f but i dont see it fixing the missfire....but that will be badass if it does though. I drove my car around a lot before getting a tune and it drove much smoother than my friends is right now. Thank you all for the advice.
Old 04-07-2005, 08:38 PM
DaddySS's Avatar
A good trick for finding vacuum leaks is use a can of lighter fluid and squirt around all suspected areas. If it finds a leak the idle will change immediately.
Old 04-07-2005, 09:08 PM
gollum's Avatar
Sounds like your plugs are fouling. Replace sparkplugs with new OEM AC plugs. Then have it tuned.
Cold nitrous sparkplugs, the wrong plug, or old plugs will foul if too rich.
Old 04-08-2005, 08:43 AM
hourang's Avatar
i would check the rear brake booster hose to make sure its not kinked and is connected. reach back and make sure the other tube is connected to the back of the intake and the connecter as well. pull the spark plugs and make sure none of them are fauled or the porceline cracked. what springs did he go with? what all was replaced? how long has it been driven since the changes?
Old 04-08-2005, 08:57 AM
my01camaroz28's Avatar
I had a problem with mine running crazy when my o2 wire shorted out. Caused the engine sensor fuse to blow. Go check that and start the cheap way. If that fuse is blown it is causing your maf to freak out.
Old 04-10-2005, 04:27 PM
00Formula's Avatar
Turns out all the plugs were fouled.....replaced them all and now it is 100% better. So now the car is goin to TSP for a tune on Tuesday and should be good to go. Thank you all for the help and suggestions.
Old 04-11-2005, 09:47 AM
hourang's Avatar
yeah i dont know why people would even bother not changing spark plugs on a header install, its like the best time to do it. glad you figured it out.
