Im gonna do it open noid
i have a wet with powershot solenoids. I want to run it open noid what fuel jet should i put in it for the fuel with open noid for nitrous.
Well the powershot has a .076 orifice, but what nossle, it may be the limit. Anyways, that's in the 175/200hp range and fuel jets are .038/.044 area. You need to start smaller and work your way up, dyno or data log or? you need to be careful, because if done correctly you can probaly get away with this. If your not going log/dyno make it rich to start with? Now I'm just giving suggestions here.
