Which PCM to use
Old 04-07-2005, 03:21 PM
Big Geek's Avatar
Default Which PCM to use
I have a motor/wiring harness from a 02 T/A and was wondering if a PCM from an 2000 LS1 would work properly on it. The reason I ask is that I bought the HP tuner software for my 2000 LS1. Obviously something is different or the software that I have would work on other years as well, but what is it? Meaning what would I have to change to be able to use the 00 PCM and is it cost effective? If not should I just go ahead and get a PCM for an 02? Thanks for the help.
Jim C.
Old 04-07-2005, 03:33 PM
horist's Avatar
The 00 PCM will work , the main differences are the operating system in the PCM , not the PCM itself
the wiring harness for the 02 will be missing things such as the EGR wiring, but the 00 PCM will work fine w/the harness
Old 04-07-2005, 06:52 PM
Big Geek's Avatar
Thank you for your help.
Jim C.
