Do I need a deep tranny pan?
Old 04-07-2005, 05:39 PM
BoneSS's Avatar
Default Do I need a deep tranny pan?
Going w/ a 4200/2.35 str stall and have a 24k cooler. Do I need the pan also? Thanks!
Old 04-07-2005, 07:29 PM
LS1LT1's Avatar
It's not mandatory but it really could help, the cooling benefits and extra fluid are good insurance to have with a bigger stall like that IMO.
Old 04-08-2005, 11:36 AM
Ragtop 99's Avatar
Keep an eye on your temps if you FTRA, but it is probably not needed if you have a 160 T-stat and matching fan settings
Old 04-08-2005, 02:39 PM
BoneSS's Avatar
I have none of those parts...
Old 04-08-2005, 07:46 PM
Moderator
JNorris's Avatar
I do not think you really need one but I bought one of the GM truck pans (GM part # 24215535) with the drain plug. The drain plug is really handy and it holds about 1.5qts more fluid than the stock F-body pan.
John
Old 04-08-2005, 08:26 PM
CamaroCain's Avatar
I did all the precautions possible for my tranny; cooler, deep pan, & trans temp gauge.
Old 04-09-2005, 03:53 AM
BoneSS's Avatar
Thanks for the input! Something to consider. I will be down there anyway...
Old 04-09-2005, 09:44 AM
4mula's Avatar
a larger pan is a good idea. ill be doing one soon myself
Old 04-09-2005, 10:51 AM
Yank's Avatar
With that stall you need to replace the LOST fluid that happened with the use of a smaller converter.
The smaller converter uses about 2 Qt's less fluid and that is lost in your system that is one reason that there can be cooling problems in some setups!
always go for an increase in the system of no less than 1 Qt more that stock for a converter more than 2000 rpm over stock.
Good luck
Old 04-09-2005, 10:56 AM
ULTIMATEORANGESS's Avatar
Good luck
thats good info.i never knew that.
Old 04-09-2005, 10:57 AM
BoneSS's Avatar
Thanks--that is some great info. Looks like I need to change the tranny fluid while I am in there
Old 04-12-2005, 03:12 PM
BoneSS's Avatar
Is it a must though? Concerned about ground clearance.
Old 04-21-2005, 04:42 AM
BoneSS's Avatar
What pans do you all have?
Old 04-21-2005, 01:10 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Smile
I have a Y3000 2.0 STR in my 01 Z28. I have a B&M 24K cooler and a B&M 3Qt. deeper aluminum pan. My trans temps on the freeway (hot day or cold) never rise above 140F. In town my temps run a little higher between 150 & 175 depending on the outside temperature. I live in a very warm climate.
If your vehicle is NOT lowered, go for the B&M 3Qt. aluminum pan.
SteveC
Old 04-21-2005, 05:17 PM
BoneSS's Avatar
Old 04-21-2005, 09:27 PM
BoneSS's Avatar
How about the TCI pan that Speed Inc sales? 2 qts extra...
Old 04-21-2005, 09:34 PM
the more capacity the better.
Old 04-22-2005, 07:09 AM
SteveC's Avatar
Any quality deeper ALUMINUM pan is the way to go, they are more expensive than the steel counterparts, however they disapate heat better.
SteveC
Old 04-22-2005, 03:11 PM
BoneSS's Avatar
I think I will just get the B&M.
Old 04-23-2005, 07:49 AM
SteveC's Avatar
Smile
Good choice, providing your vehicle IS NOT LOWERED. This pan hangs down low, on my stock height vehicle I have 5" clearance from the ground to the bottom of the pan.
SteveC
