239/243 112
239/243 112
after talking to a sponsor this cam was recomended for my goals... 239/243 112LSA alogn with a set of AFR 225's going in a stock LQ4. the car will hopefully be backed by a t400/3800 stall and 12 bolt. anyone have any ideas what kind of power i might make through a 90/90 intake and LT's and how it will act???.... the afr's are back ordered at least 2 months... also ive been talking to people about P2V clearance issues with no milling to the heads and stock pistons... no one gives me an answer they just say " its a big cam"...?? TIA!
Two examples of similar cams. Your in between. You might be ok. Its your call. Be safe or gamble... P2V
Camshaft: 237/242, .603"/.609", 113 LSA - Clears Stock Pistons with Stock Cylinder Heads!
242/248 - .608/.612 - 110 Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads.
what else you guys think i should get into with the motor itself? im ordering up some rod bolts and the upgrade spring if i do end going the AFR. but what else oil pump ect? trying to stay with stock short block obviously but aside from pistons,rods .....
