Would exhaust leak cause o2's to throw codes, idle/run rough, bad gas mileage?
Old 04-09-2005, 12:08 AM
MeanWS6's Avatar
Default Would exhaust leak cause o2's to throw codes, idle/run rough, bad gas mileage?
trying to nail down my problem, either bad o2's or exhaust leak.
Car runs like crap, cant idle, black smoke, sluggish from a roll, and HORRIBLE gas mileage
Can't find any exhaust leaks anywhere, will continue looking in the morning with some daylight instead of my crappy garage light
getting:
P1153: Heated Oxygen Sensor (HO2S) insufficient switching
P1133: other side
Do you think its the o2's or I have an exhaust leak???
Old 04-09-2005, 12:21 AM
snake charmer's Avatar
sounds like the o2s might need to be replaced. the computer will dump extra gas since it does not know accuratley what it should be mixing.
Old 05-15-2005, 02:20 PM
70T/A400's Avatar
Change your oxygen sensors. They are probably caked with carbon from running too rich. It is common with long tube headers.
Old 05-15-2005, 02:52 PM
blkZ28spt's Avatar
If you change O2's get some made for the C5. Bosch part #13111 at autozone is one way to get some.
Quick Reply: Would exhaust leak cause o2's to throw codes, idle/run rough, bad gas mileage?
