Ran 12.5@115 on the juice today...
Old 04-09-2005, 09:07 PM
SDB
SDB's Avatar
Default Ran 12.5@115 on the juice today...
Went to the track today, weather was good, track kind of sucked. I didn't get any NA runs, only got three runs total (I usually go on test-n-tune Wednesday nights, Saturday sucks ***, wait all day to get three runs).
2004 GTO with following mods
150 wet kit NX
homemade CAI
NGK TR6's gapped at .038
Timing Tuner, pulled out 6 degrees of timing, window switch set at 3000 and 5900
intank Walboro 340 fuel pump
3/4 tank of gas (93 octane)
Stock tires at 27 psi in rear, 37 psi front
265lb driver+65 lbs nitrous system, left spare tire in
Everything else absolutely bone stock, including tune, tires, suspension, gears, no other boltons, etc...
short times were horrible, 2.0
Ran 12.5 @ 115mph (GTECH registered 3 mph higher, but .1 slower than timing lights....makes sense since the trap speed is an average over last distance for the 1/4 mile via timing lights, so it should be lower than actual highest speed attained). Track is about 800-900 above sea level elevation (Muncie Dragway, IN.)
car hooked up great, no spin at all, but felt real sluggish off hte line and when the nitrous kicked in at 3000 rpm, it spun (even wheel hopped one run, a 12.7 run). It feels much better on the street, will spin a little when nitrous hits, but NEVER wheel hops...I think with a 3000 stall converter to get into the nitrous MUCH quicker and some tires it will be an 11 second car. It feels like it takes FOREVER to get to 3000 rpm with the auto!!!! I think I may try some nitto's to see if they hold the car when the nitrous hits, make pick up a tenth or so that way. Overall, fairly hapy with results for first run. I will get a tune to see if that helps any...
I would assume that my car runs 13.7-13.8 @101 on motor (based on GTECH from the street)....will run NA when I get a chance. Saw a new 05 GTO, automatic run 13.3 @ 106 twice (with his 14 year old sister in the car), pretty impressed with that car! Seems to be about a 1/2 second faster than the 04's and his was bone stock with 1500 miles (mine has 4000 miles). I am betting that my homemade CAI gain is offset from added weight of nitrous system and using the cold tight gapped plugs...
All the issues I had with my nitrous were due to a "used" timing tuner, put a new one on and it worked great. I tried using less timing retard...5 degrees seemed OK, but when I added more timing (-4 instead of -6) it detonated and blew the dipstick up a little, making sure my coilpacks never rust (sprayed a little oil, nothing big). I still get KR on the street with no timing advance or retard off the bottle, and at -6 timing, I get basically none (about .1) on 150 shot. I will get a tune and maybe desenstisize the Knock Sensors, play with torque management, check timing and fuel and spark to see if we can make things run better on motor and check AF ratio on bottle. I am hoping for 12.0 on Nittos and with the tuning...maybe a little optimistic. I don't want to put a converter or exhaust on the car, because I love it stock in terms of sound and driving....I have a fast Camaro for hillbilly racing, the GTO is too nice of a daily driver to hop it up any further (things that would hurt drivability).
SDB
Old 04-09-2005, 09:35 PM
14 Second Truck Club
mzoomora's Avatar
That is an awesome MPH! Lots of room for improvement with better 60fts. Nice job.
Old 04-09-2005, 09:51 PM
SDB
SDB's Avatar
Yeah, I probably gained about 15 mph, which is typical for 150 shot on totally stock LS1....I feel that the homemade CAI actually kills low end power, it doesn't spin nearly like it did with the factory air intake sealed system...but the trade off is nice up top, better pull. I really think a converter and Nitto's and this would be a 11 sec. car.
Old 04-09-2005, 10:39 PM
Black02SS's Avatar
Congrats on the times. I could never get really good traction at Muncie. US 41 seems to be better for traction.
Old 04-10-2005, 01:15 AM
john shea's Avatar
Cool! You must be at the max safe shot with 150 shot
and stock internals
Old 04-10-2005, 09:20 AM
Black02SS's Avatar
The 100 does me just fine for now.
Old 04-10-2005, 07:11 PM
crAzy95Z28's Avatar
youd be a good race with me being n/a, but spray im in the 11's
Old 04-10-2005, 10:58 PM
SDB
SDB's Avatar
150 or nothing....150 is fine on a stock engine, especially since I have no other power mods and I have a Walboro and a timing tuner...no problems...
On the street I beat a lot of stuff that SHOULD run better than a 12.5 at the track. I beat an 03 Cobra from a kick tongiht that has 495 rwtq on a Mustang dyno at Livernois Motorsports....from 30-100 I had him and pulled him a little. I was real surprised...I may assumed I would jump him since the nitrous hits hard with all the torque, but I expected him to pass me about 70-80 mph, those things pull good up top.
Old 04-11-2005, 11:43 AM
robul's Avatar
I ran yesterday with headers/cold air/ 100 shot and the best i could muster was a 12.6@114.
once i shift to forth sometimes it falls on its face and I have to let out. .I guess I am running out of fuel. Can you give me some details on the walbro you used and where you got it from?
my car is an 04 gto m6
Old 04-11-2005, 03:40 PM
SDB
SDB's Avatar
SHouldn't be running out of fuel on 100 shot with no other real mods....may be running lean with headers if untuned....Are you pulling any timing? I get KR on 150 shot that required 6 degree of timing out....I would scan it, couls be pcm is detecting KR and pulling a bunh of timing in 4th gear under heavy load and feels slower.
