New LS1 Owners - Newbie Tech - 84K miles, what should I do?
View Full Version : 84K miles, what should I do?
Nick D
04-10-2005, 04:03 PM
My car is getting to be a high mileage beast. What precautions should I take in order to make sure my car makes it to 184K miles?
stevensLS1
04-10-2005, 04:10 PM
prolly just the usual. change ur oil. and basic maintenance.
00Z28 Camaro
04-10-2005, 04:13 PM
not so much precautions as maintenance , mabey the high milage oils, grease bushings change fluids idk
Third Gear
04-10-2005, 04:14 PM
Stay on top of the maintenance. Use a high quality synthetic oil like Mobil 1, German Castrol 0w-30 (green color), and Amsoil. :)
Nick D
04-13-2005, 02:06 AM
Standard maintainence is always a priority of mine, I was just wondering if I need to change the timing chain or anything else major to that extent.
jaberwaki
04-13-2005, 03:23 AM
changeing your timing chain is not a "bad" idea, i would add to that list checking your valve preload, ect ect... there is really nothing stopping you from checking the tq on every bolt you can see... it really depends on how involded you want to get...
infinitebird
04-13-2005, 03:33 AM
Why not reset the clock?
408 stroker :devil:
jaberwaki
04-13-2005, 04:28 AM
because that would require good clutch, supporting hydrolics, 9" rear, nitrouse driveshaft,tq arm, and about 30,000 bucks give or take to do it right....
