Need help installing my trans cooler on my 98 TA
I bought a trans cooler for my 98 TA and how do you hook it up? do you just splice and connect one of the cooler lines to the bottom of transmisson line of the radiator? and leave the top transmission line alone in the radiator? also how should i mount the cooler? Is it better sideways? or mount it up and down?
You want it in a series with your factory cooler. The factory cooler "in" has a pressure fitting and is the bottom line on the radiator if I remember correctly. The "out" is the top line. Just put your new cooler in-line with the factory out. That really sounds like I'm explaining this shitty and making it complicated when it isn't.
Mount the cooler to the front of your radiator for maximum cooling. It's a bear to do because there's no room near the top but it cools better in that position.
Originally Posted by Flame Throwing SS
You have it backwards. The top is the in-line for the OE cooler, the bottom one is the out. Otherwise the system would starve when the trans fluid level is low, killing your trans. The bottom line is used to feed the trans incase this happens and will always allow fluid to flow into the trans.
