Ru2n00n3er
04-11-2005, 07:32 AM
Just put a Shaner throttle body on this weekend that I had picked up used. When I first started it up, it sat at 1000 rpm for a while but eventually fell back down to ~800. Now it won't even do that anymore, it just stays at 800. At first I thought it was just taking a while to get to idle, but now it doesn't go back to the same idle at all. I can correct this by adjusting the idle screw stop correct?
I'm also getting a service engine light now. Haven't gotten it scanned yet, but what is it most likely? I thought about if I didn't have the plate centered and if it would catch when it swings shut, but I made sure I didn't hear any contact sounds before it snapped completely shut before I put it in. I'm almost positive that's not the issue, so what else could it be? I've reset the pcm once and it still came back. This TB also came with sensors and I have those on now, I might swap them for my original sensors and see if that takes care of it.
