Motor Math Questions
Old 04-11-2005, 08:18 PM
TATER's Avatar
Default Motor Math Questions
What's the deal on motor building?
If I have a ____ liter bare block with a _____ bore, a _____ stroke crank, a _____ inch long rod, how do I figure up displacement? Also, how do I know what depth of piston I'd need to give the valves room?
Is there a book or a web site I could read?
Old 04-11-2005, 08:21 PM
Ben R's Avatar
Cubic Inch Displacement = bore x bore x stroke x number of cylinders x .7854
The piston depends on how big your cam is (duration, not lift), what your quench is, and how much free-drop your cylinder heads have, among other things.
Old 04-11-2005, 08:27 PM
smask04C5's Avatar
bore X bore X stroke X 6.2832= cid
Old 04-11-2005, 08:31 PM
TATER's Avatar
Sweet, thanks! Found a low mileage 6.0 out of a rearended pickup, and thought I might have some fun with it.
Old 04-11-2005, 08:33 PM
silverbullet00's Avatar
What do you have up your sleave t8
Old 04-11-2005, 09:24 PM
SSU'S Vice Mod
sb427f-car's Avatar
Or you coulda used the volume of a cylinder and multiplied it by 8
Old 04-11-2005, 11:03 PM
TATER's Avatar
Nothing right at the moment. College is expensive, but I may or may not have a bare block on an engine stand to play with and learn on until I get some time and cash.
Old 04-11-2005, 11:38 PM
cyphur's Avatar
here's jrp's displacement link in his SuperFaq with the full equation. its quite accurate. i'd use that one if you want a trustworthy number.
