Dynamometer Results & Comparisons - What kind of power should i expect???
crafty
04-11-2005, 10:47 PM
I have a 98 Z-28 a4, i'm having the ls1 rebuilt. It has a stock crank, stock rods, Diamond pistons, copper head gasket shims, 2002 ls1 heads, Comp 918 springs, ls6 intake, Thunder racing 224 224 112lsa, Kooks LT headers, Texas speed and performance true duels, ported throttle body, stock converter, stock rearend. Please give me a round about est. of the numbers i will turn out.
White 02 WS6
04-12-2005, 12:15 AM
It all depends on numerous things...Is the engine rebuilder boreing the block alot or just enough to clean up the cyclinder walls? Are the heads stock heads or have they been modified? What compression ratio? If you plan on racing the car alot, your not seeing your cars full potential without a converter. With stock 241 casting heads, normal 346 cubes, 10:1 compression ratio, and an a4 car id say any where from 370-385.
crafty
04-12-2005, 09:38 AM
the head gaskets are supposed to increase the compression by one point, stock bore size. this car is my daily driver what size converter should i run, i'd like to keep the gas milage up. thanks
White 02 WS6
04-12-2005, 03:38 PM
The Precision Industries Vigi or Yank 2800-3200 would be fine as a daily driver...Some people daily drive a 3500-4000 stall though, its up to you...If it were me I would do a 3200-3500 as a daily driver...
crafty
04-12-2005, 03:48 PM
ok thanks alot for you advice
Silvr98z28
04-12-2005, 03:58 PM
horsepower :jest:
ls1_doc
04-12-2005, 04:38 PM
i drive with a 3400 stall everday and i love it
M6HuggerSS
04-12-2005, 07:14 PM
id guess, 350-360rwhp
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
