How to 15x3 skinnies fit on LS1 Fbody
Old 04-12-2005, 09:22 AM
SS346Ls1's Avatar
Default How to 15x3 skinnies fit on LS1 Fbody
How much grinding does it take? We ground off a pretty good bit!
Wheels are 15x3.. or 3.5 weld drag lites... came off an Lt1 car.
Old 04-12-2005, 09:36 AM
gator's 99TA's Avatar
simple. no grinding needed. buy a set of 5/16 wheel spacers up front. fixed. grind for the back as there are a lot more load back there.
Old 04-12-2005, 02:07 PM
SS346Ls1's Avatar
The spacers didn't fix the problem. It still seems to want to compress the calipers.
Old 04-12-2005, 02:34 PM
Derek98z's Avatar
a 5/16" spacers should work with a 15x3.5 wheel. Which backspacing does the wheel have? If I recall, there is a 1.75ish and a 2.25ish.
Old 04-12-2005, 04:11 PM
SS346Ls1's Avatar
Not sure.. the way its acting I'd guess it was the 1.75?
Quick Reply: How to 15x3 skinnies fit on LS1 Fbody
