are 98 f-body cams the bad ones???
Old 04-12-2005, 12:28 PM
jimmyp's Avatar
Default are 98 f-body cams the bad ones???
I was reading somewhere that certain year ls1s had better cams than others. Ive got a 98 right now and since its apart I was wondering if it would be worth it to swap in a used corvette cam...(newer the better??) since they seem to be pretty cheap?
What would I gain as far as hp, tq ...revs???
Would I "need" to change anything else as far as lifters or springs?
I will be having the computer retuned either way after it goes back together.
thanks!
Old 04-12-2005, 12:32 PM
Tranzor's Avatar
98-00 ls1s have the same cam (both F-bodies and Corvettes) while '01-'02 have a different cam.
The only Corvette that has a different cam is the Z06, which has an LS6 cam. The LS6 cam would be worth swapping out your LS1 cam for if saving money on a cam swap is your biggest concern.
Old 04-12-2005, 12:33 PM
jrp
SN95 Director
jrp's Avatar
the oem ls1 cam differentials are inconsequential. if your gonna swap in a cam the bare minimum i would do is 220 duration.
Old 04-12-2005, 12:36 PM
jimmyp's Avatar
ok so even the newer standard c5 cams wouldnt be worth my time to swap them in...only the ls6 ones (which im sure arent dirt cheap).
I dont really want to spend too much money on this motor right now since I dont really know its history/condition.
Old 04-12-2005, 12:53 PM
jrp
SN95 Director
jrp's Avatar
ls6 and hot cams dirt cheap relative to aftermarkect cams. im sure an ls6/hc and springs could be had for 300 or less.
Old 04-12-2005, 01:06 PM
777's Avatar
any stock cam is a "bad one"
Old 04-12-2005, 01:09 PM
jimmyp's Avatar
there is a 01 z06 cam in the for sale section with springs/retainers for $150. How much would I gain with that?
Old 04-12-2005, 01:11 PM
Tranzor's Avatar
You can get an '02-'04 LS6 cam for about the same (maybe a little more)... the '01 LS6 cam is not nearly as good as the '02-'04 versions.
jrp
SN95 Director
jrp's Avatar
i'd say ~20rwhp @ peak. the 01 is the smaller cam out of the ls6 motor, the 02's got a larger one.
01 204/211 .525/.525 116lsa
02 204/218 .551/.547 117.5lsa
thats off the top of my head.
Old 04-12-2005, 01:16 PM
jimmyp's Avatar
ok so just hold out for an 02-04 then......like i said I want to make sure this thing runs before I spend any more money on mods. But after that.....
20hp with the 01...how much would you say with the 02-04s?
Old 04-12-2005, 02:31 PM
Derek98z's Avatar
spend the extra money on an aftermarket cam with some lope. you'll be glad you did it right the first time
Old 04-12-2005, 02:57 PM
cyphur's Avatar
get a hot cam, and some 918 springs. you can prolly get it for ~300 like jrp said. you won't be disappointed, but the LS6 cam isn't worth the gain imo.
Old 04-12-2005, 03:07 PM
jesserose17's Avatar
With LS1 Hot cam, according to previous owner, it dynoed at 358hp & 359 lbs of torque. It had long tube headers, cold air intake and Flowmaster Y-pipe with straight through turbo muffler. I think that's pretty good...
Old 04-12-2005, 05:16 PM
Another_User's Avatar
That is not correct. In 2000 the C5 had a higher lift cam with a 115.5 LSA. It was the equivalent of the better 98-00 F-body cam, but with a better LSA. And actually the cams above and below 2000 were close, but not the same on the C5s.
Old 04-12-2005, 05:27 PM
Tranzor's Avatar
That's correct, but they are all VERY close if not the same. Point being, not worth the change...
Old 04-13-2005, 06:38 AM
SAM98WS6's Avatar
if you are going to a cam anyhow...do it right...T1 or TR224 or something like that and new springs/pushrods...which need replaced anyhow.
Old 04-13-2005, 06:48 AM
DrkPhx's Avatar
FYI - There were some 98 F-bodies installed with the Corvette cam during mid-production run.
Old 04-13-2005, 11:45 AM
jimmyp's Avatar
i wanna say the build date on mine engine was late 97.....any way of checking to see?
Old 04-13-2005, 04:00 PM
I feel sorry for those guys. That cam was crappy. Those were probably reverse-factory freaks, slower than most F-body cars.
Old 04-13-2005, 04:44 PM
12stones's Avatar
I agree, just go ahead and take the extra $200 and buy the cam that best fits your requirements.
