comp cam 224/224 .581/.581 hp#'s?
Old 04-12-2005, 08:22 PM
SStheBest's Avatar
Default comp cam 224/224 .581/.581 hp#'s?
just wandering how much hp u could get with this cam in a stock setup?
Old 04-13-2005, 11:37 AM
TARyan21's Avatar
I have this cam in my 02 WS6 M6. I made 350 rwhp with only a Loud Mouth Catback untuned. I have added a lid and got an awesome tune from RWTD.
I haven't dynoed again but I would be safe to say without the headers I am still putting down 370. RWTD told me that I should have between 370-390 with their tune but I will stick to the bottom number and personal feel. I will post my numers when I get it dynoed again.
Old 04-13-2005, 12:52 PM
SSU's Drunk Typing Whore
Lithium's Avatar
about 380 or so, if you have all the bolt ons to go along with it.
Old 04-13-2005, 07:27 PM
dalejr8ls1's Avatar
im running a very simular cam and with a stock stetup your looking at about 350's. Match that cam up with some heads and screw the 300's.
Old 04-13-2005, 07:56 PM
SStheBest's Avatar
is that just with a cam and exhaust?....meaning u dont have headers, intake, yipe......
Old 04-13-2005, 08:23 PM
TheBowtieboy's Avatar
That exact cam on a 112 LSA +4 advance
All the bolt-ons, stock cc 241's with a 3 angle valve job.
Only 364 RWHP 356 RWTQ
BUT I make 350 RWTQ at 2700 RPMs and that holds almost completely flat until 5600 RPM's (keep in mind peak was 356)
.....I had the heads "tweeked" with low end torque in mind but they also stall out at 5600 as well (normally would make power much higher into the RPM range)
This was with cats, 3:73's, running a tad lean (13.3) and an exhaust leak.
I see no reason why (with stock 241's) you couldn't get 370-380 out of this cam with most bolt-ons.
Old 04-14-2005, 03:45 PM
Tough Mudder
Hilton's Avatar
HEY! Let's talk a little more about this cam!
Are most people pretty happy with it? How did it work out?
Old 04-14-2005, 04:30 PM
SStheBest's Avatar
lol i wanna know myself....thats y im askin
Old 04-14-2005, 05:29 PM
Derek98z's Avatar
I did 374/375 with stock 10 bolt, LS1 intake, LT headers, olt ons
see my new post in the dyno section after changing a zillion things, but still running the same cam
416/376
Old 04-14-2005, 10:05 PM
racerfoo's Avatar
365rwhp, 351rwtq, untuned w/ 10.5 air/fuel, stock heads, ls6 intake, asp crank pully, light flywheel and driveshaft, through an rx7 IRS rear end.
Old 04-14-2005, 10:12 PM
Ryan02SS's Avatar
TR224 112 here. Stock heads with all boltons and tuning made 399rwhp @ 386rwtq thru ORY @ open QTEC.
Old 04-14-2005, 10:14 PM
SLP CARS '98's Avatar
415rwhp 387rwtq with stock 10 bolt
Old 04-14-2005, 10:16 PM
I'd like to know what 1/4 mile times people are running with this cam.
Old 04-14-2005, 10:23 PM
NHRAFORMULA00's Avatar
380 hp auto the rest is in sig.
Old 04-14-2005, 11:34 PM
AmMscl's Avatar
I'm running the Comp 224 581 114 = love the power and idle.
Great driveabilty and made 430RWHP (with LGs and AFR 205s) came highly recommended from Tony@ AFR.
Old 04-15-2005, 12:11 AM
glennhl's Avatar
I have the Comp XER 224/.581/112 cam. I really like it, pulls real hard all the way to 6900. I shift at 6600 in 1st and 2nd and then let it run out the quarter mile in third crossing the lights at 6900. I made 381 hp with headers and a cutout. And that's with stock pulleys and throttle body.
Quick Reply: comp cam 224/224 .581/.581 hp#'s?
