Gears & Axles - wheres the differential removal/installation writeup WHATTHEHECKAREALLTHESEWIRESHELP!
Stone0fFire
04-12-2005, 10:15 PM
i ordered a stock 3.23 differential from our sponsor TENNESSEE AUTO
and i pick it up from compton tomorrow
so before i pack the M1911 and roll three cars deep to try and get in and out without leaking transmission fluid all over my own seats,
how do i get my stock differential out?
i removed the driveshaft and torque arm
but thats the end of my know-how
now what do i do?
is there a writeup on how to remove the diff?
maybe to install?
swap?
help? :confused:
wrencher
04-12-2005, 10:55 PM
The whole rear end housing? Since you undid the T/A & drive shaft, now disconnect ABS sensor (s)( 3 or 4 channel)
Remove the calipers & mounting brackets. Unclip the brake lines from the axle tube crimps. Undo all the supports & stand off's from the rear diff. cover . Undo the parking brake cables. & push the ends thru the retaining bracket by compressing the retaining clips. Undo the lower control arm bolts. Then remove brake line/parking brake retaing bracket from housing. Postion it up w/ brake lines & calipers so it is out of harms way for the housing removal. I usually use bungie cords to hold them up. Unbolt the panhard bar from housing. Have housing supported w/jack & stands, undo the lower shock nuts & then drop the housing down & remove springs, or they will fall out.
Make sure to keep springs & rubber's orintatied properly for re-installation.
Stone0fFire
04-13-2005, 01:05 AM
thanks!
too bad i dont know the names of all these parts here..
but my friend has the haynes manual
this helps tremendously..
thanks alot!!! =)
DietCoke
04-13-2005, 01:38 AM
Just unbolt everything connected to it. If its bolted, unbolt it. Easy enough principle.
WS6WRX
04-13-2005, 03:13 PM
are we talkin the whole rear axle here?
KCRickSS
04-13-2005, 03:30 PM
I found this link the other day...hope it helps.
http://www.xse.com/leres/ss/differential.html
There is at least one site that I found recently that is more detailed but it is sitting on my computer at home.
WS6WRX
04-13-2005, 05:20 PM
http://www.fullsizechevy.com/fscu/axletech/
http://nick_novotny.tripod.com/install.html
Stone0fFire
04-14-2005, 07:47 PM
well the whole thing is out
and the whole thing is in
i even have all these parts leftover!
it drove fine
just got to recalibrate from 3.73 to 3.23
thank you everyone for your help
i didnt have the cash for a mechanic
and if i did
id buy a wheel and ditch this donut
