General Maintenance & Repairs - Worried about oil filter size
FelixIlka
04-13-2005, 11:05 AM
I'm going to make the switch to Mobil 1 5w30 tomorrow, but yesterday I went to the dealership and bought a filter, I brought part numbers with me ( UPF58 and PF44 ) and the guy said he's never heard of UPF58 and that PF44 has now changed to PF46..
http://img128.echo.cx/img128/4530/pf461kq.gif
Does that look like the right filter? I said to the guy that looks extremely small for a 5.7, my intrepid 3.3 takes a bigger filter than that and he said even the big trucks use it..
Weezzer
04-13-2005, 11:17 AM
get the PF-59 with the anti-drain back valve.
BTW-After several bad oil analysis reports (I never had a good report with this oil) I'll never use Mobil 1 in my LS1 again.
felton316
04-13-2005, 12:12 PM
LS1's use a very small filter compared to earlier versions of the 5.7 liter. Since our filters are located in an upright position, the anti-drain back valve is pretty useless for this application.
can you show me the oil analysis so i can see why mobil 1 is so bad...
msbz_ls1
04-13-2005, 04:20 PM
I've used Mobil 1 in my 98 Transam since 60k and it now has 90k and it runs like a champ!!!...great oil pressure still..as if new...I also ran Mobil 1 in my 1994 Camaro Z28 it did GREAT!! also...i"ll always use Mobil 1 as long as its still made..and i can't believe you just made allegations...such as Mobil 1 will never be used in your car again...
MOBIL 1 Rules!!!...:P
msbz_ls1
04-13-2005, 04:21 PM
Now you got a good report.
Weezzer
04-13-2005, 05:05 PM
That is incorrect, it keeps it from flowing opposit from what you are thinking, it helps keep the oil up further in the head than filters without the anti drainback valve.
Weezzer
04-13-2005, 05:09 PM
Don't believe me, ask Patman for his opinion, or go to
bobistheoilguy.com
and look at some of those reviews.
I will NEVER run mobil 1 in my LS1 engine again, I did 4 oil analysis and got four bad reports, perhaps its working differently for you-I'll trust my reports. My oil anaysis are posted at the above site and I'm pretty sure a couple of times here (could have been ls2.com). Just search for it.
Mobil 1 5W-30 and 10W-30 are just barely a 30 wt oil, after just a couple of thousand miles it's sheared down to a 20 weight. I even added one qt of 15W-50 to the five regular quarts. Oil did get thicker but there was NO improvement in my analysis, the last batch I dumped out at 1620 miles-it was the first half way decent report on this oil that I've gotten.
This topic has come up before, like I said - do a search.
I was so pleased with the analysis results of the German Castrol that I now use I'm going to keep using it.
MikeyS2k5
04-13-2005, 05:44 PM
Im with msbz_ls1, I thought Mobil 1 was one of the best? (Next to German Castrol) :confused:
just pm patman since he is the oil man
TheBlurLS1
04-13-2005, 10:17 PM
i recently switched to the long (pn: 2006) k&n oil filter and it boosted my oil pressure a bit.
i WAS using the FRAM filter because i thought that an oil filter was an oil filter :barf:
i was under the impression that the anti-drainback valve helped prevent the oil from draining to protect against dry startups. at least that's what it said on the k&n filter box.
FelixIlka
04-13-2005, 10:35 PM
So is this the right filter?
cowboysfan
04-13-2005, 10:46 PM
so using K & N oil filter how often do u change filter? :confused:
Patman
04-14-2005, 05:40 AM
It should easily last 10,000 miles, so there is no need to change your filter unless you're running over 10k intervals (and I don't think anyone here does)
02_Phase2_ZL1
04-14-2005, 05:50 AM
As a suggestion, you could use a Mobil 1 oil filter. The information that I read some time back put Mobil 1 oil filters at the top of the list right behind the Purolater Pure One. The direct replacement filter is a M1-107 but I use the longer filter which is a M1-206. I also use a Filter Mag oil filter magnet. There has been a lot of speculation as to whether the oil filter magnets work or not, but I will continue using it just for that "perceived" extra protection.
Fulton 1
04-14-2005, 08:05 AM
AC Delco PF44 is the stock filter size that's recommended in the manual. PF58 is a larger capacity version of the same filter. It has the same 13/16-16 thread size, same overall diameter, and the same gasket diameter and thickness - its just about 1" longer. UPF58 (and any UPF's for that matter) are the now-defunct AC Delco Gold filters. The PF59 is same as PF58 except with an anti-drainback valve, which as stated above, is useless in this application. I haven't heard about a switch to a PF46, so I can't comment on that.
If it were me I would look at a PF58 if you want the AC Delco filter. Otherwise I'd look at a Wix 51522, NAPA Gold FIL-1522 (made by Wix), or a K&N HP2006 (best choice IMO - especially if you want high flow), which all cross-reference to the larger PF58.
HTH
Patman
04-14-2005, 06:22 PM
The antidrainback valve is most certainly not useless, which is why all new GM cars now get filters with them. The antidrainback feature will keep the oil in the passages above the filter upon shutdown. Without the ADBV, this oil directly above the filter would go back to the oil pan. So even with a vertical mount filter like on the LS1, the ADBV does indeed help.
Weezzer
04-15-2005, 04:44 AM
Exactly! And since the majority of engine wear is instigated during engine startup (due to lack of lubrication)-the ADBV helps to mitigate this problem.
ABadMother1999
04-15-2005, 05:53 AM
Oils used in your car can vary and people can feel one way or another about it. Some people might complain about a syn oil like "Mobile 1" being bad but alot of times it is because of how it was applied.
If your using a general non-syn oil for a good amount of miles and then just out of no where you go to a fully syn oil, your going to encounter alot of problems... Some consisting of gasket leaks, poor lubercation, or even the wieght of the oil changing fairly quick.
I would suggest, if u started with a non syn oil to possibly go to a blended oil. I used durablend personally to kinda prep the motor for a possible fully syn oil change. Id run this for a good 4 or 5 oil changes and then changed to a fully syn oil.
From personal expirence... I have no leaks, a friend of mine who went from a citgo motor oil straight to a syn oil... sprung quite a few leaks. So this would be one suggestion for future reference.
Back on subject... I know the model numbers for a CarQuest oil filter for a 99-02 5.7 are "B4006", you could go to the local shop and have them interchange the numbers (like what u did with the other brands and product/part numbers)... Goodluck on your search for the RIGHT filter!
I hope I was to some help!
When using a full syn motor oil whether it be castrol, mobile 1, valvoline, etc...
twocam99
04-15-2005, 07:36 PM
Just put in a K&N HP-2006, it boosted my pressure a little. The filter is bigger then the stock one. It looks about 25% bigger
Fulton 1
04-15-2005, 08:48 PM
Patman, I'm under the impression that the ADBV is basically a one-way valve to keep oil IN the filter for startup purposes (something that was useful on my old Quad4 with a horizontally-mounted filter). In the case of an LSx with a vertically-mounted filter, I suppose that whatever spring tension that there is in the rubber valve can keep some oil in the passages above the filter, but is it really an appreciable amount?
Patman
04-16-2005, 05:15 AM
Yep, because when you remove your filter, and you see how much more oil comes out of that area, that is the amount which would've simply gone back into the pan. It's at least 1/4 of a quart.
Fulton 1
04-16-2005, 10:24 AM
Interesting. I never really paid attention to that. Thanks for setting me straight. :cheers:
Mr Incredible
04-22-2005, 09:18 AM
To learn a lot about how oils perform, engines age, and oil myths fall by the roadside:
Oil Life Study on Z28 -- http://neptune.spacebears.com/cars/stories/oil-life.html
Oil Filter Dissection Study -- http://www.scuderiaciriani.com/rx7/oil_filter_study/
Very informative and revealing.
As for filters, get a quality filter and change it regularly. K&N is good. Mobil1 filters are good, too. Just don't buy a Fram oil filter.
No need to go overboard and change your oil and filter every 1000 miles, but there's no sense in buying cheap oil and filters for the automobiles that mean so much to us.
so..........
whats the latest reccomendation for replacing the pf44?
FelixIlka
08-24-2005, 12:58 PM
so..........
I just used the K&N 1007 or the PF46 works aswell ( used that one for my last oil change ).
