problems with my NX kit.....help please :(
Old 04-13-2005, 02:17 PM
mulletwearingtadrive's Avatar
Default problems with my NX kit.....help please :(
i was at the track the other day and i had a full bottle but my nitrous was not working. i have an NX wet kit with a bottle heater, fuel pressure safety switch and a bottle opener. this is my problem........i will arm my nitrous and then stomp on the gas, it will hit in one gear and then when i shift...nothing. its like it just dies. i have it set on a WOT switch
any ideas as to what could cause this? all my fuses and **** are working fine, i checked it all out.
Old 04-13-2005, 04:39 PM
silverZ98's Avatar
chould be your fuel pressure is droping after you chage gears to low and your FPSW is cutting it off.
Old 04-13-2005, 05:06 PM
Nitro Dave's Nitrous Outlet's Avatar
Thats what it sound like...
Old 04-13-2005, 05:44 PM
so should i get rid of the FPSS? what can i do?
btw, i am thinking about picking up a window switch? good idea?
Old 04-13-2005, 06:29 PM
bad2000ss's Avatar
It would be a great idea.
Old 04-13-2005, 09:36 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
I would highly recommend a window switch also!
http://www.speedshop.org/store/Scrip...?idproduct=138
Dean
Old 04-19-2005, 01:23 PM
a window switch will be ordered soon but is there any other advice you guys could give me to troubleshoot this problem with my nx kit?
Old 04-19-2005, 01:45 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
An easy way to check the fpss is to take a small L E D inside the car. Give it power from the arming switch, and then its ground connect to the relay side of your FPSS. light stays on your good. Something else to check, the wot switch, make sure at full throttle there is complete closure or contact. If it is pull you seat up a couple of motches, the launch could be setting you back in the seat just enough to turn the system off.
Our new dual window switch upgradedable to progressive system later in life and for the money you can not go wrong.
Ricky
Old 04-20-2005, 12:11 AM
Robert56's Avatar
Ricky, your killing me. Need new switch, yes!
Not to disscount other input, the way I check a fpss is just jump it post to post with wire (same as removing) then try it. Depending on switch sometimes they are not set correctly from factory. A lot of guys don't use one because of erratic operation, I do and reccomend one.
Old 04-20-2005, 12:36 AM
6 Second Club Moderator
LASTLS1's Avatar
When I first started using nitrous I had noting but problems with that switch. I took it out and watched fuel pressure! It worked for me.
