need Cam help with my 205 AFR heads?
Old 04-13-2005, 09:03 PM
disposer's Avatar
Default need Cam help with my 205 AFR heads?
i have a 2000 Camaro with full bolt ons, 90mm FAST LSX, MAC mid length+ Y pipe, Borla cat back, 3000 Stall TC
just got my AFR 205 Heads but i dont know what Cam Shaft would perform best for my set up?
what do you think about the MTI G1 (228/232 .588/.575 113 LSA) ?
what Cam shaft do you think that would perform BEST for my set up and for both N/A and N2O? ------> (150 wet shot NX)
thanks guys
waiting for help
Old 04-13-2005, 09:40 PM
Spellbound's Avatar
thanks guys
waiting for help
I have direct expierence with two cams and AFR's, A third very shortly.
Look in my sig for one example. The other one was with the same heads and a MTI stealth 2 cam.... all I can say is, Don't use that cam with those heads. Third cam is the one That AFR recomends, 224/228 581/588 114 + 1. I am just waiting for the energy to swap heads again, lol. I stole them from my gf and she wants them back, lol.
Old 04-14-2005, 02:54 AM
prostock_bigblock's Avatar
G5X3 all the way bro dont really think about it ...
Old 04-14-2005, 08:05 AM
CHRISPY's Avatar
I would go with the AFR cam 224/228 114LSA 113ICL. That'll work great on spray and make good all around power NA
Old 04-14-2005, 08:24 AM
PREDATOR-Z's Avatar
For all around street >>>AFR 224/228, it is tailored for those heads obviously.
Old 04-14-2005, 12:53 PM
disposer's Avatar
What is the Duration for the G5X3 114 LSA
i couldnt find it at LG motorsport ????????
Old 04-14-2005, 01:00 PM
PREDATOR-Z's Avatar
And you won't unless someone that has it discloses it to you.
It is a little bigger than X2
Old 04-14-2005, 01:35 PM
disposer's Avatar
and where can get the AFR cam shaft 224/228 ??
i couldnt find it in there web site 2 ????
what the F** if wrong with them !
Old 04-14-2005, 01:37 PM
mike c.'s Avatar
i just finished installing the AFR and g5x3 combo. i feel if you go with the 224/228 cam you'll be leaving power on the table. the x3 cam idles great and don't shake the car bad. it drives nice on the street and best of all it pulls hard all the way to my 7,000rpm redline.
Old 04-14-2005, 02:02 PM
disposer's Avatar
so what is the Duration of the G5X3 ?
is it good for Nitrous and N/A ?
Old 04-14-2005, 02:05 PM
disposer's Avatar
did you Dyno this Combo !!
AFR 205 and G5X3 cam shaft ??
what was the HP and Torque?
and how was the Power under the Curve ?
Old 04-14-2005, 02:20 PM
PREDATOR-Z's Avatar
The G5X3 is is more of a max effort cam VS the AFR 224/228 (street friendly)
Low useable Trq in the 224/228 comes on earlier in the rpms which makes it more street rpm oriented.
G5X3 will make more trq but will peak later at rpms higher than the usual street daily driven use.
Old 04-14-2005, 04:50 PM
mike c.'s Avatar
my x3 cam is street friendly and i'm still on the x2 tune. no serging or stumbling no loss of low tq. it's street friendly.
