Who has had a probelem after a rod bolt install into a stock shortblock?
I have read a ton of threads on this, and most people do not have a probelem replacing the rod bolts. I have heard of some running into issues with cap distortion, but only heard. I've never heard anyone say, "I spun a bearing 2 days later."
So all those people who have had probelems with using
-ARP pro series cracked rod bolts
-ARP regular cracked rod bolts
-Katech cracked rod bolts
..please post up and tell us what happened! Otherwise it will be safe to assume no one has had an issue afterwards.
i have installed them twice before. once in a car that blew up. the rod snapped in half the only think left was the arp bolts! they were still holding the two haves together. and a new ls6. he had 0 issue's with it. the concern is that the rod bolts fit in the rod with the collar a bit tight. but there isn't enough pressure to cause any rod cap distortion. i used a rod stretch gauge to combat any torque issue i may of had because of the snug fit.
I believe the ARP bolts have a piloting feature so you don't have to worry about cap shift. I work for Federal Mogul and have done numerous engine dyno tests and taken bearing traces in the rod after bearing assembly. We would see cap shift all the time with the old bolts. But GM now has a piloting feature on OE bolts and ARP should have the same. You should be fine.
The idea here is for people to be able to replace rod bolts in their stock motors, and most do it while the engine is still in the car. So checking the rod and/or resizing it is NOT a feasible option in that situation.
Good to hear that there were no issues with engines after bolt installs. Keep the results coming!
