Pontiac Firebird 1967-2002 - weight reduction?
View Full Version : weight reduction?
CATCH ME
04-13-2005, 10:41 PM
i have a 2000 T/A and wanted to do some weight reduction, yet still keep the 4 seats and the ability to put 4 people in the car (rarely). also i dont want to cut anything. what is the cheapest way to do this and where else should i post this??
99FormulaM6
04-14-2005, 07:23 AM
theres always the spare tire/jack. :) but the backseat is the most common. get lightweight carpet.
~JOSHUA
04-14-2005, 01:26 PM
Do you mind losing the entire AC system? Install a lightweight "K" member. Swap the exhaust manifolds for headers, aftermarket suspension components are liighter and stronger than stock(usually), and if you have a metal fuel tank you could replace it for the '01+ plastic ones, carpet-soundeadener, replace the power antenna for a fixed one,tire/jack, take out the bumper supports, run less than 1/2 tank of gas,
Together I'd say 300lbs.
ACW
04-14-2005, 07:22 PM
Weight reduction list thread: http://www.ls1tech.com/forums/showthread.php?t=17319 :)
