Oil leak from the filter..help
Yes it's possible its to tight. When you change it make sure you wipe down the base of where the filter screws onto and put some oil on the filters gasket. Only hand tighten...when you screw it on easy and it starts to not go on with your fingers just give it a good 1/2 - 3/4 turn and be done with it.
Also check the old filter if you still have it and make sure the old seal come off with it. If you don't have the old one check and make sure the old seal isn't stuck in the housing. I have had this happen to me before.
