Cadillac STS SAE 100
BALLER ***!! is the only way I can seem to describe this vehicle. http://www.fast-autos.net/cadillac/cadillacsae100.html
Awesome stuff man. There were rumors of a CTS-VR and while I know it won't happen, an STS-VR would be just as awesome. A supercharged LS2 can't be argued with. I'm guessing the most probable production piece/combo on this car is the automatic transmission coupled to the blown LS2 under the hood. While a proper Corvette should be self shifted, it's damn time they replace the aging 4 speed autos in the slushbox cars with a transmission that has a few more ratios. They've already adapted the 6L80-E into the XLR-V and packaged it at the rear of the car so it shouldn't be too hard to get it into the Vette.
Speaking of the hotness that is the XLR-V... http://www.fast-autos.net/cadillac/cadillacxlrv.html
It would seem that putting a pushrod engine in a Caddy would be going backwards at this point, even an LSx. That kind of power can be made with a Northstar, wonder why they didn't use one....
Well there definitely isn't anything "backwards" when you're talking about an LSX. Pushrods do not make an engine ancient as the LS7 and even the LS2 demonstrate.
I think you got the wrong idea about what I said.
Technically, pushrods are older tech. Even when dressed up in fancy PCMs and exotic materials. The Northstar is a more advanced base design which could be dressed up in the same stuff, get higher revs, and make just as much power, and maybe even be lighter.
I was just saying that since Caddy is supposed to be the techology flagship, I would have figured on them using a hopped up Northstar, or making a new generation of it, is all.
Believe you-me, I fight against people who deride our stuff as ancient and worthless all the time, and would kill for an LS7 (if only for the @90lb savings over the LS1).
Originally Posted by technical
You have a point. Even though pushrod engines aren't exactly antiquated, most "un-knowning" buyers treat the OHC world as advanced.
Originally Posted by Steve1969LS1
OHC has been around a LONG time.. the pushrod motor is here to stay as evidenced by the LS7 which is far and away more advanced than most motors..
Jaguar was using them in the early 30's. A financially troubled car company can't to afford to develop a new engine for it when they have one that is more than capable.
I'm sure they didn't use a maxed out Northstar due to warranty concerns. I'm sure that's why they didn't go N/A on the lsx to achieve it.
