Valve spring replacement?
Old 04-14-2005, 06:30 AM
kapsz28's Avatar
Question Valve spring replacement?
How much work is it to replace all the valve springs? Do the heads need to be removed or anything? About how long should it take to replace them?
Old 04-14-2005, 07:51 AM
Bill Bowling's Avatar
Talking
It took me about 2-3 hours to replace mine but I also did cam, pump,etc.
Heads stay on. Just remove valve covers. Get the Larry Tool. It works great.
Bill
Old 04-14-2005, 08:53 AM
luv2spd's Avatar
I got mine done in about 1.5 hrs using the crane tool.
Old 04-14-2005, 11:26 AM
~JOSHUA's Avatar
Here's the best tip we can give you on that. Go to www.LS1howto.com - It will show you step by step how to do that. Good luck!
Old 04-24-2005, 09:18 PM
kapsz28's Avatar
Is it more common to break an intake valve spring verse the exhaust valve spring? This is the second time I have broken an exhaust valve spring and both mechanics thought it was strange that it was the exhaust spring that broke.
Old 04-24-2005, 09:27 PM
glennhl's Avatar
Not sure which break more often: Exhaust or Intake Valve Springs. Which springs are you breaking. Are they the stock springs or an aftermarket valve spring? The reason I ask is if you are making 375 rwhp and you think you have a stock cam, I'm betting there is an aftermarket cam in your car (assuming you bought the car used and don't know for sure). You may want to put a dial indicator on the rocker and measure the lift, stock should give you around .5" times 1.7 rocker arm ratio for a total of .85 inches. If you are running stock springs with an aftermarket cam you will start breaking them right and left.
Old 04-24-2005, 10:22 PM
01_SuperSlow's Avatar
with the crane tool it ahouldn't take you any longer than 1.5 hrs to change all springs.
Old 04-24-2005, 10:25 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Old 04-24-2005, 10:29 PM
kapsz28's Avatar
I bought the car new. Mods are in the sig. They are Manley springs. Everything installed and tuned by SLP.
Old 04-24-2005, 10:37 PM
blkZ28spt's Avatar
What cam?
Old 04-25-2005, 10:48 AM
kapsz28's Avatar
Originally Posted by blkZ28spt
What cam?
SLP cam.
Camshaft Specs: Valve Lift Duration Duration@.050 in: .559" 267º 214º ex: .566" 275º 222º
Old 04-25-2005, 11:49 AM
WS6 RULES's Avatar
Another vote for the Crane spring tool. Just did the cam last week and my first time changing springs on a LS1. It was quick and easy.
