Should I void my 3 year warranty for TD's?
Im really stuck, just bought a 2002 SS, i wanted true duals w headers, with an x pipe and all....but then i realized that the previous owner bought a $3000 extended warranty on the car that lasts till 2008, it covers EVERYTHING! I was told that if i keep the aftermarket exhaust CAT BACK, ill be cool if anything should happen to the engine...but if i add headers and all, it voids any engine coverage...WHAT SHOULD I DO???
Thanks, all opinions welcomed
what I would do. is put the headers on, install the xpipe with td's and then keep all the hardware that was on the car. this way if somthing does happen. just take the headers and xpipe and td's off and put it back to stock. that is what i would do.
When I was younger, I would have done what 1FST99Z suggested. What other mods do you intend to do? If you want a ton of mods, I would probably just do them and discard the warranty. If all you want is exhaust, I would probably do a nice cat-back and call it a day. GMMG might be a good choice if you go this route.
The "fine print" usually says they can stick it in and turn it sideways at their discresion. But if they care about their reputation they wont.
I would do the mods and keep the old parts for incase you need warranty work. Only problem is if the smallest thing breaks then off come the parts.
I know i couldnt wait until the warranty went out, id do the mods and if something huge went wrong hope they couldnt blame it on that.
hey thanks everyone! Ill go ahead n hook er up...screw the warranty...not worth it..
Erik
Erik
Go for it, you only live once,.
Originally Posted by ULTIMATEORANGESS
if you dont care about your extended warranty cancel it before you start modding and get most of your money back.
that should cover a good amount of your exhaust parts.
you will not void your warranty by putting on duals and headers....
hey have to prove that those parts caused something else to fail before they can void your warranty...and even then.... they can only void it for that part...
meaning they cant void your water pump because of headers...they could void your 02's if they wanted to...
again...problem has to be proven that it caused failure before it can be voided for that part.
Originally Posted by 9silverbird8
Can you do that? Cancel and get a partial refund I mean.
Erik
Erik
hold on to your stock stuff and put those mods on and switch em back. but if you dont want to do that, then just cancel that damn warranty. the previous owner spent 3k on that warranty not you. and besides those warranties are all shady anyways. they wont cover things that should be covered sometimes anyways. and remember if you got any weird noises or strange things going on in your car, you can always count on the guys here on ls1tech to help give you an answer to your problem.
Yea, maybe I can get some money back for that warranty that I didnt spend money on...that would be sick...i could put that towards mods...
then again, I am 20 years old, if something major were to happen due to plain bad luck, id have a broken SS sitting for quite a while considering i work a part time job...
erik
erik
Most things don't break due to bad luck. They break because we tend to abuse these things. After all, there is a reason we aren't driving beaters.
Some guys like to make the factory pay for their stupidity. They swap everthing back to stock after they have blown the tranny so that you and I will have to pay for it the next time we buy a new car. Nothing is free - they just push the cost off onto people that come along later.
If your gramma drove the car, nothing would ever break. Simple as that. So the warranty is essentially useless unless you want to make the rest of us pick up the cost for your breakage.
Now there is a very, very low probibility that something might happen wherein the warranty would come in handy and would be legit. But the probability is so low that you will be money ahead to ignore it.
Sears makes more money on warranties that it does on product sales. Stop and think ... they could not offer things like extended warranties if they lost money. What it comes down to is insurance. You are betting that the car will break when you buy a warranty. They are betting that it won't and they have the numbers to know that they are right. If you are willing to take responsibility for you own actions, you will save a lot of money in the long run by avoiding warranties. (and also full coverage insurance - same principles).
