Air and Fuel System Sale
Old 04-15-2005, 09:15 AM
Craig@ETPerformance's Avatar
Default Air and Fuel System Sale
FAST intake manifolds
54003 - 90mm Reg $889.99 Sale Call/PM/E-mail
54001 - 78mm Reg $779.99 Sale Call/PM/E-mail
Ganatelli Mass Air Meters
75mm Reg $279.99 Sale $264.95
CPR Fuel Rails
LS1 Fuel Rails with fittings Reg $209.99 Sale $184.95
Fuel Pumps
255LPH Intank fuel pump Reg $129.95 Sale $114.95
Fuel Injectors
30lb injectors Reg $269.99 Sale $239.95
36lb injectors Reg $379.99 Sale $329.95
42lb Injectors Reg $399.99 Sale $329.95
Valve Spring Kits
.625 Lift Rev Valve Springs, Titanium Retainers,Locators, Factory Locks and Valve Seals Reg $299.99 Sale $259.95
Save an extra 5% off your order, if you order Intake/Rails/Injectors as package.
Thank you,
Craig
Old 04-15-2005, 04:36 PM
Z06PSI's Avatar
How about some injectors in the 70lb range..... whatever max is for the stock PCM....??
Old 04-16-2005, 09:13 PM
janders's Avatar
What brand are the injectors?
Old 04-18-2005, 09:07 AM
Pm's sent to
SuperchannelKEV
TAV8TR
bmfcamaro
Old 04-18-2005, 09:30 AM
The 30lb injectors are Bosch. The 36's and 42's are CPR injectors.
Pm sent to redrumss
