Vacuum valve plug for AIR removal?
11Second Club
I looked at this article and saw that a vacuum hose would be left open upon completion of the removal of the AIR system. I will be installing race headers on a military base tomorrow morning, and I'm wondering what I need to plug this? I'm also wondering if I can plug it at a later time. In other words, will this cause the brakes to weaken significantly due to the vacuum leak?
TIA.
TIA.
Originally Posted by JEB99TA
Don't forget to pull the two fuses for the A.I.R. pump when you remove the system.
11Second Club
Originally Posted by GM Muscle
They make little rubber vacume hose caps. I think I got mine from Napa. You could probrably even stick a screw in it of you wanted.
And, if I don't cap it right away, are there any serious detrimental effects to worry about?
They usually come in variety packs (size wise) and should be pretty easy to find. I'm not sure on the size, maybe 3/16" or so. I'm not sure how the car would be affected leaving it uncapped. If you can't find any of those caps just grab anything you can to plug it temporarily and order some caps from Summit.
I just always go the extra mile ... had a wiring harness burn up because an unneeded circuit was not disabled and it got up against the exhaust and ground a couple of wires out ... one just happened to be the hot lead from the AC that had been removed from the vehicle ... probably wouldn't happen again in a million years, but, that experience made me overly cautious. Not really necessary to pull the fuses ... just keeps the circuit live is all.
