Stripped allen head bolt
The bolt is actually not even on my car, its on the mnotorcycle im tryin' to fix. Its got a rounded head like a machine screw so vice grips are out. I was gonna try the dremel thing but that took forever last time and I just wanted to see if anyone had any other ideas.
Originally Posted by 9silverbird8
Just like it says. Anyone got any ideas for removing that sucker?
http://www.caseytool.com/twistsockets.html
http://www.arizonatools.com/catalog/...1038&catId=116
will work
http://www.etoolcart.com/browseprodu...AHN-11135.HTML
is the kit I use
12 pt torx bits can also be pounded i nand used to remove em
I get to deal with lots of stripped allen and torx becasue the germans seem to think they are the cats *** ......................they arent
will work
is the kit I use
Originally Posted by DynoDR
How about a "twist socket"?
best tool I bought off the matco lady
Originally Posted by tuff
If you had a welder you could weld a nut over the stud and weld through the nut to the stud like a plug weld.
will work
is the kit I use
will work
is the kit I use
Please help!!!!!
Thanks in advance.
Moderator
Every motorcycle owner ought to have a hand impact driver.
They cost about 10-20 bucks and come with a 5/16" hex that
takes Philips (so you can back out those crusty Jap bike
case screws and replace them with Allens) and a 3/8" square
drive head (so you can put an Allen bit on there). A 2# baby
sledgehammer and a little wrist tension, and these suckers
work great. The happer forces the bit into the fastener just
when you need it to.
Not all of them come with the 3/8 square socket bit, watch
for that. The cheap $6.99 Harbor Freight one looks to not,
but I've picked up flea market ones for 5 bucks that did.
http://www.sears.com/shc/s/p_10153_12605_SPM3278860402P
The nature of combining steel fastener and aluminum, over time, vibration, expansion, contraction and galvanic action will ended up with difficulty in fastener removal.
I have SnapOn, IMO, use good tools to avoid the painfull damage controls!
Moderator
The cool thing about the hand tool is that you're actually
driving the bit into the workpiece just when you need the
seating force to fight cam-out. An impact gun, you can lean
into it but that's still only a hundred or so pounds of in-force
(unless you're sitting on it). But the "impact" is pure rotary.
If the Allen in question is rounded beyond help, another
idea might be to get a slightly oversized Torx bit, call it
expendable and use the hand impact tool to pound it in
and hopefully grab. Maybe bevel the lead face a hair, to
help it in.
help it in.
help it in.
help it in.
Not trying to be argumentive, TIA!!
