Best looking Bogart wheels???
LS1Tech Co-Founder
I'm considering getting a set of D10's, I think they would look very nice on my 98 red Formula hardtop, but I'm open to other designs. Which ones are the best looking in person?
I looked high and low for about a year and couldn't make up my mind. I will say this that when looking at the pictures of the bogarts on SJM's site the pictures do not do any of them justice.
I had decided on the Welded R/T's because it seemed like cleaning around the bolt holes would be a major pita and it also was a very nice, clean looking rim that kept with the 5 spoke design and althouth it has some reference to a pro-star (probably my second choice) it was different and not every one had it. I guess that can be good or bad depending on how you look at it.
Here are the welded on a Mustang that I found out on the net.
Here is a picture of the welded rim (fronts) that showed up to my house from Steve
The bolted rims seemed nice in the rear but they had too much metal in the fronts IMO. It seemed like the outer rim was too large visually. I'm sure they are designed that way for a reason but it looked not quite right to my eye.
