Best/easiest way to clean injectors??????
Good gasoline would be a great start. Mobil 1 gas is loaded with quite a bit of detergents (I guess you would call them) that clean and keep injectors clean very well. Or you could use your choice of fuel injector cleaner in a bottle, some guys like to use the Seafoam if your familiar with it in their gas tank. Or you can go to local shop with a fuel injector cleaner where they flush the injectors out with some type of pressure machine or some crap which cost some bank. Depending on your mileage of your injectors and if they really are caked up and not firing normally Id spend the money on the local shop to clean them or buy new injectors haha. If low mileage and your thinking you just want to do it because your a maintenance freak which is not a bad thing, just run a good gasoline or fuel injector cleaner in a bottle. Good Luck
