orangeapeel
04-17-2005, 06:20 AM
I ran across this the other day and just thought that I would pass this handy info along. If you have Cruise Control on your M6 you may or may not be aware that the clutch ties into the cruise control. There is a module with a button on it and it has to be pushed in at least halfway for CC to work. The CC module is threaded so you can twist it to mate up correctly with an adjusted clutch pedal. If you have an adjustable master and are trying to adjust it and pull the pedal closer to the floor you might run into this problem. I thought that i broke something under the dash. So if your cruise control stops working after you put in a new clutch or mess with the drivetrain...that is probably what it is.
