LS6 Vs. LS2 Bolt-ons
Old 04-17-2005, 03:46 PM
UtOhCop's Avatar
Default LS6 Vs. LS2 Bolt-ons
Here's my question. Taking both an LS6 and an LS2 and bolting on the same mods to each engine. The LS2 will produce better gains correct?
Has anyone cammed an LS2 yet? What kind of numbers are they putting down? Only reason i ask is because my LS1 shortblock is making some weird noises and am considering a potential LS6 or LS2 swap into my C5.
Old 04-17-2005, 03:54 PM
Wnts2Go10O's Avatar
i would say the ls2 would because of the extra cubeesss
Old 04-17-2005, 07:13 PM
niphilli's Avatar
Mee Too, only drawack is that tuners are not as good with LS2 edit as LS1 edit yet. That will come with time though
Old 04-17-2005, 09:49 PM
ChucksZ06's Avatar
Go with the larger bore. It does not matter if ls2 edit isn't out yet. The car has an ls1 pcm. The engine block has nothing to do with the pcm.
Old 04-17-2005, 10:00 PM
UtOhCop's Avatar
I've been told that the LS1 pcm would have no problem controling the LS2. We'll see. The LS6 is 900 dollars cheaper
