Northwest Members WA, OR, ID, MT, WY, SD, ND
LS1 engine tools
Old 04-18-2005, 12:41 PM
NataSS Inc's Avatar
Default LS1 engine tools
Does anyone have the engine tools for the LS1. the one I need right now is the one that will hold the flywheel in place so I can take tha balancer/clutch etc off. Or is there an alternative way. I would just need to borrow it for one night to get the thing disassembled.
Old 04-18-2005, 01:11 PM
WAHUSKER's Avatar
Can't you just stick a phillips screw driver thru a hole in the flywheel to hold it while you break the bolts loose?
Old 04-18-2005, 01:31 PM
NataSS Inc's Avatar
I dont know if that will hold when I am trying to pull the crank bolt out. And I dont want to risk damaging the block if the screwdriver breaks and gouges the block.
Old 04-18-2005, 01:35 PM
Ackattack1's Avatar
I assume the tranny is not connected. The screwdriver or prybar method will work....used that method on 2 autos.
Old 04-18-2005, 01:39 PM
NataSS Inc's Avatar
The motor is out of the car.
On an iron block I wouldnt have a problem using a pry bar but the aluminum is a bit softer and I dont want to risk damage. Unless someone knows it can be done I dont want to guiney pig anything on the only block I have.
Old 04-18-2005, 02:26 PM
WAHUSKER's Avatar
I ordered the flywheel locking tool, but it never came in. So I grabbed the largest phillips I had & stuck it thru a hole in the flexplate. It made a small dent in the block tab above the strater, but nothing that would affect anything. I guess I'd have to look at the motor sitting out of the car to decide for sure, but I think it will work just fine. Is it home, or at Don's?
Old 04-18-2005, 03:38 PM
sardog46's Avatar
Git a big impact and it will come loose without even turnig over the motor.
Old 04-18-2005, 03:47 PM
NataSS Inc's Avatar
Thats what Ellis said to do. the motor is at Dons place and he has all the air tools to do the job.
Old 04-18-2005, 05:45 PM
WAHUSKER's Avatar
My impact wouldn't budge mine, but Don's got the real deal so maybe....
Old 04-18-2005, 09:09 PM
TwoFast4Lv's Avatar
Yeah it is a little easier with a New Snap-on 8 vane Impact I freaking love mine! I get off every time I fire it off
Old 04-18-2005, 10:12 PM
tjwong's Avatar
I got one of them Ingersol Rand Ti2135 or whatever its called. It rips them LSx balancer bolts off without even breathing hard
Old 04-18-2005, 10:38 PM
Racehead's Avatar
Well maybe you should hold it a little further away from ... ahh .... yourself
Old 04-19-2005, 01:12 AM
TwoFast4Lv's Avatar
hehehe. The best way I can equate it is going from a healthy 6 cyl to a Healthy V8!
Best hundered bucks I have spent in years!
TjWongs is a heavy hitter also. The TI serise kicks Butt!
Old 04-19-2005, 08:21 AM
code4's Avatar
check this out;
