LS6 block ever in a camaro?
Old 04-18-2005, 02:56 PM
SJTrance's Avatar
Default LS6 block ever in a camaro?
I have a friend who has a camaro SS. He says that it's the special edition SLP version with the LS6 engine in it. I just chocked it up to his normal way of exaggerating things, but then, he put a cam in his car and pulled over 400 hp without heads. It's an aggressive cam, but nothing out of this world (230/237 ish). Now, I'm thinking...does he have a LS6 block? I think it's an 01 or 00. I did a search on SLP camaros and I understand that all SS Camaros are basically SLP "tuned" camaros with some SLP parts like the intake, wing, and other various parts. If I sound like a moron, please forgive me. I'll try and find more information if you want, but what can you tell me about the LS6 block/engine history in a Camaro. I just read in another thread that the WS6's in 00 and 01 came with an LS6 block.
Also, if you do put an LS6 short block in an LS1 car, what are the gains and what is the differences? Where does the LS6 make it's power? Is it in the cam and heads or does it go far beyond that? I'm sure it does because Z06's respond much more aggressively to the same set of heads/cams than a regular C5...right?
Thanks for listening to the ponderings of a newbie.
Old 04-18-2005, 02:58 PM
BADFNZ's Avatar
Maybe an LS6 block but not an LS6 engine. The LS6 block is a darker grey color if he wants to check. There is NO power difference between the shortblocks. If he thinks he has an LS6 engine from the factory then you need to find new friends.
Old 04-18-2005, 02:59 PM
01SSDRVR's Avatar
15% of 01,02 F-body's had the LS6 block.
Old 04-18-2005, 03:00 PM
777's Avatar
ls6 block has better oiling...in reality there is no difference...ls6 engines make the power in the cam, and the heads...hince ls6 heads which raise the compression
Old 04-18-2005, 03:15 PM
Tiger2o69's Avatar
I have the ls6 block. No real advantage. Better cooling is pretty much it. Makes it slightly weaker I have read tho.
Old 04-18-2005, 03:58 PM
SJTrance's Avatar
So would I make the identical power from my LS1 if I change my heads and cams to LS6 heads and cams (and maybe the LS6 intake)? Of course, I won't do that since I would be going to a more aggressive cam.
Or to rephrase the question...
If a Z06 and an '01+ LS1 C5 has the same aftermarket heads and cams, would the power output be similar/same? Of course, I understand that the 1/4 mile times will be lower due to the decreased weight.
Old 04-18-2005, 04:00 PM
That's what she said...
TheBlurLS1's Avatar
better *oiling*, you can read about it in one of JRP's stickies in the top of the new users forum.
most reguard the ls1 block as being more structurally sound. it also offers the same power levels as an LS6 block. the ls6 in the z06 vette also has a better PCV system that runs out the front of the valley cover.
Old 04-18-2005, 04:02 PM
TheBlurLS1's Avatar
theoretically, if they had identical heads/cam packages and similar exhaust setups (headers to mufflers), they should make the same power.
if your car is a 2001 or newer, you already have the LS6 intake manifold
Old 04-18-2005, 04:04 PM
SJTrance's Avatar
Well, my car is a 99, but I've read that this might or might not really be producing power.
Old 04-18-2005, 04:07 PM
Wnts2Go10O's Avatar
jus do bolt ons anda cam and ull be set
Old 04-18-2005, 04:48 PM
SJTrance's Avatar
What other bolt-ons are there other than the pullies?
Old 04-18-2005, 05:46 PM
UtOhCop's Avatar
You really need a cam SJ. Once you do it. you'll ask yourself why you didn't sooner.
Old 04-18-2005, 05:49 PM
LoPeY's Avatar
If you're talking about the LS6 intake manifold, it will produce more power.
Old 04-18-2005, 06:20 PM
SJTrance's Avatar
Well, from reading this, I guess it sold me on cams along with heads.
Now, I'll just have to sell the idea to my wife.
Old 04-18-2005, 06:29 PM
oange ss's Avatar
better breathing ,not oiling
Old 04-18-2005, 06:31 PM
SJTrance's Avatar
Whoa! A contradictory statement. I'm tuned back in. Anyone like to respond? Better breathing must mean more power, right?
Old 04-18-2005, 06:33 PM
SiL3NtXWS6's Avatar
Did you ever get the cam in?
Old 04-18-2005, 06:34 PM
SJTrance's Avatar
I still have to get some more things. I have to hide some money from the wife...you know how it goes. I'm thinking that I should have found a cam with a 112 LSA, so I might sell the cam. It's not going in the car for a couple of months anyway.
Old 04-18-2005, 06:39 PM
SiL3NtXWS6's Avatar
it is a 112 lsa...
Old 04-18-2005, 06:41 PM
SJTrance's Avatar
Yeah, I might end up selling this cam. We'll see.
