Do I need an APHB?
Old 04-18-2005, 07:54 PM
Andros's Avatar
Default Do I need an APHB?
I plan on putting on 17x9.5/18x9.5 on my T/A and was wondering if I need an APHB. I don't plan on lowering it and the offset is going to be 56mm which is the stock offset and the tires are going to be 275/40 17/18. Would I need an APHB?
Old 04-18-2005, 07:55 PM
XtinctHawk02's Avatar
No.
You would only need the bar, if you plan on lowering the car. This is used to re-center the rear of that car after being lowered.
Old 04-18-2005, 08:01 PM
Andros's Avatar
Ok thanks, I asked Sam Strano and he said I should get one. But that was when I told him I might lower my car with koni sa and rubber isolator.
