Banging Y pipe solutions?
Anyone have any pics or exact details on how to fix the banging ORY problem? I've adjusted as much as I can and it still bangs under WOT. I also do not want o use the BFH mod on the floor either
Is the only fix a solid driver side poly mount? If so, where can I find one and how much will it generally cost?
Thanks
Brandon
Thanks
Brandon
Running pacesetter here. With a hooker ORY with no banging issues because of this
http://www.thunderracing.com/catalog...&sid=528#P3780
The motor mounts are another way.
RIP April 14, 2008
Location: the land where cars repeatedly hit my bumper when I'm in the store...
11Second Club
Where does this hanger go? I have a QTP Y and it's banging on the driver side only.
Also, does anyone else have problems with the driver side on QTP Ys? Or did I just do a terrible job of installing it?
Originally Posted by jet_black
I thought about the hanger too at first, but then I thought about how the engine was still moving, but the pipe was not, and then I thought about how much stress that would put on the header flange.
Long story short, I installed the polys, and couldn't be happier.
RIP April 14, 2008
Originally Posted by SLPSS01
do a search in this forum, someone posted pictures of it installed a while back.
To the others. Thanks for the help thus far. Where can I get a single poly mount for the driver side? Or should I search for that too....
Originally Posted by BrandonSS
Really?!?!? Wow thanks man... so helpful I said above I did a few searches and came up with answers but no pics. Why not post a link if you did the search and found it? Whenever I call a repost I at least post a link to something that is helpful instead of cluttering the thread with a useless agrivating answer that does the person absolutely no good.
lol.
Here is the thread:
https://ls1tech.com/forums/showthrea...hlight=Mufflex
Looks like the pictures have been taken down.
I'll be installing mine on Friday, I'll take some pictures.
Here is the thread:
my QTP y banged under the center console. the skidplate or whatever you call it didn't have enough clearence between it and the merge. i fixed it with some washers.
