Strange 12 bolt rearends on sale!
We have the Strange 12 bolts on sale through Friday, April 29th. This will save you $240. off of the regular pricing!
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars)
$2189.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin)
$2189.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. (Axles don't have to be sent in if you don't have traction control) $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles.
The backing plates are only required for 1998+ cars.. $229.99
Orders can be placed online or by calling 1-877-482-9763.(1-508-636-0770 in MA). Strange is currently running about 4-5 weeks out in production so orders placed now should start shipping towards the end of May. This will give you time to plan on when your stock 10 bolt will break during this year's racing season!
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - tbyrne@tbyrne.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
$2189.99
$2189.99
