Anyone running 17" ET Streets?
You might have an interest in this thread. M&H is considering building a similar tire that would actually be an inch wider (true 10" footprint). They are looking for indication of interest to move forward with this project.
http://forums.corvetteforum.com/show...547&forum_id=1
I just got a set of the M/T ET Street Radials 275/40 17. My car has been down for the past month, I can't wait to try them out. Supposedly they grab much better than the BFG or Nitto's.
Originally Posted by 8KickassRS9
i see a battle brewing between the tire companies
Tony M.
i have been running the 17 et streets on the 99 vette, but this past weekend they would not hook for crap. they have more than half of original depth left, but they never got sticky all weekend long. any one else ever had this happen? i am leaning towards that mt drag radial, just like the wrinkle flex affect to aid in a little less parts shock. joe in memphis
Well I will put it like this. I broke a 9" on the Mt street radials. If they get can come up with a tire that is comparable in stickyness, and price I would be in. Even if they make it a little bit wider and the life is at least the same. I would purchase a pair to do some testing to see which one I like better
Hey Tony I agree the more the merrier. Those M/T above have an equivalent size of 26x11.50-17. Check the specs below, they meet you 10" width.
MTT-3743R $177.95
Estimated Ship Date: 5/14/05
OverviewBrand: Mickey Thompson
Product Line: Mickey Thompson ET Street Radial Tires
Rim Diameter (in): 17
Tire Size: 275/40-17
Sidewall Style: Black wall
Tire Construction: Radial
Directional: Yes
Tube Required: No
Asymmetrical Tread Pattern: No
Minimum Recommended Rim Width (in): 9.0
Maximum Recommended Rim Width (in): 11.0
Tread Width (in): 10.2
Tire Diameter (in): 25.7
Section Width (in): 11.00
Recommended Rim Width: 9-11 in.
Tire Size 1: 275
Tire Size 2: 40
Belt Construction: Steel-belted
Tire Compound: R1
Roll Out (in): 82.00
Tread Depth: 2/32
Tread Ply Quantity: 2
Sidewall Ply Quantity:
MTT-3743R $177.95
Directional: Yes
Tube Required: No
Tire Size 1: 275
Tire Size 2: 40
Tire Compound: R1
Tread Depth: 2/32
As I said in the CF thread above, a 28" version with that footprint would be amazing. Hardly any tires for 17" rims in 28", and the only one I found isn't meant to handle power. I really wish M&H went through with the drag radial they had planned in that size.
I have run ET Streets in the past and like many I ran the stock radials up front on my 04 Vette. Why? Because I did not want to spend $2200 for a CCW drag pack and there in lies the tire problem. Most of us know and MT confirms, I asked them, that ET Streets (the slicks) with radials up front are not safe. If you drive a Corvette your choices are much more limited than if you run an F-Body.
I now run the MT ET Street Radials for this very reason. Their 275/40/17 will fit a ZO6 9.5 inch rim perfectly and you can safely run a stock radial up front. This provides me with a cost effective and safe racing solution. Now, I would like to see a 305 or a 315 in a 17" MT ET Street Radial or similar drag radial. BFGoodrich makes one in an 18" but I think the MT's work better.
I called CCW about their drag pack and they told me they don't really even like to make the drag pack rims because they don't make enough money on them. I will never understand why wheels for a Corvette need to cost so much more than the 15 inch rims everyone else races with.
In my opinion for drag racing a Corvette the wheels are the problem. Come up with a wheel and tire combination that can be sold at a reasonable price and you can sell a bunch of them.
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
Makes sense for him,but sucks for C5 owners wanting to put a good tire on the back.
I'm thinking some manufacture will come up with something but it won't be cheap.
IMO the radial on the front/bias ply on the rear issue is overblown.I know people have made thousands of passes with a mixed combo on their car without crashing.
Isn't there something you guys could do to get more drag-oriented brakes on the vettes that would allow you to use traditional 15" drag rims like Prostars and Bogarts and such?
7 Second Club
I'm sure it would be big bucks.
