shifter moves when i get on it
Um an inch is not that far and your tranni mount may be fine. Does your tranni hit or thud? Get underneath the car and check for rips. If you have the stock motor and tranni mounts 1 inch of movement is not that bad. I mean think of all the people with the y-pipes hitting on brand new cars with new header/catback setups. That pipe is moving about an inch.
I'd check for rips but you probably don't need to change the tranni mount.
I drove from GA to CA w/ a broken mount (not by choice) in my 95 Z28 and I never had any problems w/ the car that could have been caused by the broken mount. But since you already have a new one I would get it on quick, its a real easy install.
Originally Posted by jninan2k2
I have gone through my fair share of tranny mounts lol real quick fix tho...had one changed in like 5 minutes just to go race some cobra....anything for the races!
unbolt 2 bolts on each side of the tranny crossmember,unbolt the bolt through the middle that goes into the mount,take off the bolts on the mount itself,work backwards with new mount.....piece of cake!
