Window switch ON/OFF points for A4
Old 04-19-2005, 08:08 PM
z28pat's Avatar
Default Window switch ON/OFF points for A4
I just want to make sure I'm setting it for the right rpms, don't wanna spray through shifts,
I am setting it for ON @ 3100 rpms and off @ 6000rpms,
pat
Old 04-19-2005, 08:11 PM
Ole1830's Avatar
Your off should be 5800 max with a stock tune.
3100 is fine for on.
Old 04-19-2005, 08:35 PM
GM Muscle's Avatar
Yep, 200rpm before the shift point is about perfect. I found that 100rpm before the shift is alittle to late and you spray into the shift.
Old 04-20-2005, 03:39 AM
zrated's Avatar
if im getting my car tuned, is it safe to run 3000 - 5900 just want to make sure dont want to accidently spray through a shift.
Old 04-20-2005, 06:17 AM
GM Muscle's Avatar
I tried that. If your shift points are 6,000rpm and the off is at 5,900rpm you will probrably feel the car spraying into the shift alittle. You can try it though, probrably wouldn't be to bad with a 100 shot.
Old 04-20-2005, 10:48 AM
zrated's Avatar
can i up my shift to 6,100
Old 04-20-2005, 08:22 PM
GM Muscle's Avatar
If you would like. I think the stock limiter is set at 6100-6150 or so. I tapped the stock limiter pretty good in the burnout box and bent acouple of push rods so if you might want to look into hardend ones if you want to start upping your shift points. For what it's worth, when I started uping the shift points with the stock cam and 1.8 rockers my times started slipping. Went as high as 6,400 but, every car is different of course.
Old 04-20-2005, 08:46 PM
10 second playa
Anonymous's Avatar
You are supposed to spray through the shifts but before the rev limiter on N20.
You don't want the N2O turning on and off through the run??
That is bad news.
Old 04-20-2005, 09:11 PM
GM Muscle's Avatar
Spraying through is a very conserversal (sp?) topic around hear. While you can hurt the motor getting in and out of it real quick on the bottle, I have yet to see a motor hurt from not spraying through. While not spraying through can cost you a tenth or so it will help save your transmission. Many people have had no problems spraying through but I personally started loosing my 2-3 shift after a day of running while spraying through. Way I see it is if you want to help prolong the life of your stock tranny don't spray through, if you want to take a gamble, spray through and shut off just before the limiter.
Last edited by GM Muscle; 04-20-2005 at 09:14 PM. Reason: Holy Shit, my grammar sucks!
Old 04-20-2005, 09:18 PM
zrated's Avatar
Im just gonna set my shift to 6000, and the window switch to 5800 and call it a day
Old 04-21-2005, 10:01 PM
z28pat's Avatar
I just ran at the track N/A and on nitrous,
N/A I ran a 13.15@107.2mph,
and on the 100 shot I ran a 12.7 @ 115mph, window switch set at 3000 to 5800rpm, it hit really hard and spun,
so next time I set it at 3900 and I ran a 12.6 @ 115mph, still spun and hit pretty hard when it came on, so I couldn't get it to go higher than 115 mph, even though it's gone 118mph before with the window switch set at 4000 to 6200rpms (shop did that)
this was on street tires, 255/40/18 Michelins at 30 psi, trying no to run slicks and blow my rear end.
pat
Old 04-22-2005, 06:21 AM
GM Muscle's Avatar
You should be able to get away with some drag radials on the stock rear without any problems. Did you try manually turning on the system at the top of the 60' instead of using the window switch as a delay?
Old 04-22-2005, 10:46 PM
z28pat's Avatar
No, I haven't tried to manually hit it,
I think I'm just going to tone it down to the 75 shot and see how it runs then,
pat
Old 04-23-2005, 09:19 PM
10 second playa
Anonymous's Avatar
I know what you are saying, but lets face it you are running N2O,
to run a number, not bracket race.
N2O is volitle enough. You shouldn't be running N2O if you are worried about breaking parts and wearing things out? Just run N/A then?
JMHO
Old 04-24-2005, 08:00 AM
GM Muscle's Avatar
JMHO
Well, if that where the case why bother with any saftey features at all. Might as well spray so hard that you lift the heads every other pass, but who cares when your going after a number. I know exactly what your trying to say but some of us like a fast and reliable dailey driver that's not a complete money pit. I've put atleast 15lbs of nitrous through my car every week for over 3 season without any issues at all other than my 2-3 shift started fading this past fall. It's pretty reliable for a low budget 11.0 daily driver and I'm positive that if I didn't go to the lengths I do to keep the car running it would be on jack stands every week with broken parts. If I really wanted to I could probrably get a 10.80 out of the car with it's current set up no sweat, but to me, it's just not worth pushing all my parts to the point of destruction.
Old 04-24-2005, 02:51 PM
1ORANGEWS6's Avatar
Do you launch yours on the spray?
Old 04-24-2005, 04:10 PM
GM Muscle's Avatar
I try not to. Every now and then I'll hit it just as the car comes out of the hole, other wise I usually have the window switch set at about 3,800-4,000rpm so there is a good delay. My main concern is my converter, it's built for an N/A set up and it doesn't have a hardened sprag. I usually stall the car up to about 3,200rpm if track prep is half decent.
This season I'm going to hit it with a dry 50 out of the hole then spray the TNT 150 on top of that about 20' out or so.
Old 04-24-2005, 05:07 PM
z28pat's Avatar
I thought it would be silly for the nitrous to turn on and off
during the run, so I'm gonna setting it at 4000 on and 6000 off and see how it runs,
pat
Old 04-25-2005, 09:47 AM
NOTFAST's Avatar
I've ran 3200-5800 for awhile.
Now I've done 3000-5800.
Next week I plan on 3000-5900. All stock tune.
