aluminum or steel??
I am now having problems bolting a ls1 flywheel to my 4.8, because I am doing a swap on my 5 speed for a t56. I can't figure out what the deal is it is like the crank shaft is different. Hard telling which flywheel I will end up using.
FWIW I have never heard of anyone putting on a billet flywheel and regretting it. It's just unheard of. For your truck you probably want something with some mass depending on size/weight of tires/wheels you have to get moving and if it's an extended cab.
