Nx kit question?
Nx kit question?
I installed my nx kit with a Bmn window switch, WOT switch, and a FPSS. What the question i have is how do i test to amke sur ethe noids work before tryin it out? Any help woulr be greatly appreciated
To test you solenoids..
Get a freind to help you.Make sure your bottle is turned off.Get a can and hold the fuel line from the solenoid in it.Bring the car up to RPM and click the micro switch.It should dump fuel into the can.Then put the line back on the nozzle and turn on the bottle then hold the nitrous line from the solenoid in the air and do the same for a split second. This is how we do it.
Dave
Dave
Yes it will work, just do like Dave says. Bring the RPM up to just over the RPM where the window switch is set on the low side and engage the WOT for just a second.
