HRE Rims
Old 04-21-2005, 09:55 AM
JayBirdWs6's Avatar
Question HRE Rims
540 TECHNICAL DATA:
17, 18, 19 and 20 Inch Diameters
7-13 Inch Widths
Custom Widths & Offsets Available
O.E. spec lug configurations
Tire Pressure Sensor Compatible
Large brake clearance
Hub Centric
540R TECHNICAL DATA:
" 18, 19, and 20 Inch diameters
" 7.5 - 13 Inch widths
" Integrated Stealth Valve Stem
" Custom applications & custom offsets
" O.E. spec lug configurations
" Straight-contour, deep-lip design
" Large brake clearance
" Hub centric
HRE’s 540R Series combines a straight-contour rim with the timeless styling of our 540 Series to create dramatic and elegant designs.
Is There a big difference between these to rims? Both rims look the sam. I'm thinking of getting a set.
Another question If anyone has these rims what size did you do all around and do you have any pictures?
Old 04-21-2005, 10:50 AM
Trent's Avatar
I'm pretty sure the R is for reverse lip design. That's why they claim the fatter lip on the 540R and the 540 does not.
