Will Predator fix my problem?
Old 04-21-2005, 10:31 AM
fivepointseven's Avatar
Default Will Predator fix my problem?
Problem:
After TC install, when going from 2-3 the car sometimes bounces off the limiter a few times.. Also sometime from1-2 it does it worse.
Question:
I picked up a used Predator and was wondering if I sent it to be reflashed would it solve my problem?
What is causing this? Any hp gains may using this?...
So, basically can the problem be fixed by paying for the $75 reflash and using the Predator? What is their website?
Thanks for the help!
Old 04-21-2005, 01:11 PM
SSpdDmon's Avatar
http://www.granatellimotorsports.com/
Yes, you can change shift firmness, shift quickness, shift points, and shift MPH with the Predator. For $75, that's probably your best bet. A little more money, you can get custom tunes from RWTD to change a lot of stuff you can't do on your own with just the Predator (ie - delete O2's, delete AIR, etc.).
