smooth bellow question?
Old 04-21-2005, 09:12 PM
Tony02ss's Avatar
Question smooth bellow question?
I have a question, have a2002 ss where are you all getting the smooth bellows from and what is the correct size. Went to home depot the 3x3 is to small and the 4x4 cuplings to big? Thanks for any help.
Old 04-21-2005, 09:21 PM
rtr2001ss's Avatar
Got mine by means of SLP, bought it through LMPerformance. Fits over the 80mm BBK TB real nice and fit over the MAF real well too, one side is a little smaller for the MAF. I did have to trim it about 12mm in lenth so my air lid would go in place. The BBK sticks out farther than stock.
rtr2001ss's Avatar
rtr2001ss's Avatar
Old 04-21-2005, 09:44 PM
JarredWS6's Avatar
i used the 3x3 but had to put it in the microwave for about 30 sec to soften it up. after that it went on with no trouble.
Old 04-21-2005, 09:48 PM
blkZ28spt's Avatar
Search for the fernco mod or (preferably) the "hump hose". SLP smooth bellows is overpriced for what it is.
Old 04-22-2005, 12:43 AM
J02BLUEZ28's Avatar
Got mine from www.airflowonline.com. Go to rubber hoses&clamps then hump hoses&reducers. Part# is 40R35SL. I think it was like $16.95+shipping and you'll have to trim it a little but it works fine with my SLP lid. I also had to buy a little bigger clamp to make the job a little easier.
Old 04-22-2005, 01:00 AM
Ole1830's Avatar
It's a 3"x3" coupling. Check post #4 (about a 1/3rd way down) in JRP's "Induction and Exhaust guide"
HERE
Matt
Old 04-22-2005, 10:06 AM
99Hawk262's Avatar
I did the Fernco 3X3 smooth bellows as well. It was less than 6 bucks and I re-used my existing clamps. I boiled mine for about 10 minutes and it slid on beautifully. Like Ole1830 said, check the "Exhaust Guide." You have to trim 1/4" off of one side, real simple with a razor. I bought two just in case I messed up the first one and it was still cheaper than any you can buy from the performance sites. I ended up giving the other one to a friend and he put his on no problem after boiling as well. It also looks pretty nice if you turn the writing down. Good luck.
Old 04-22-2005, 11:40 AM
Tommy's dad's Avatar
Yup, fernco 3X3, boil it in water to soften up,trim and slide it on.The most time consuming part of doing this mod is waiting for the water to boil.
Old 04-22-2005, 12:21 PM
98SuperSport's Avatar
be careful with the slp smooth bellows ive heard some crack/break...plastic inside ur intake worth fifty bucks and a couple of horsepower?
Old 04-22-2005, 12:55 PM
mellowyellow's Avatar
fernco here also 3in to 3in is the one you want..
Old 04-22-2005, 12:58 PM
LS69TA's Avatar
What dept. is the Fernco in at Home Depot? I'm going there tonight and may try to pick one up to see if it fits better than the bellows i have now.
Old 04-22-2005, 01:01 PM
plumbing just ask someone where the couplings are..
