low coolant light, but its full.
coolant light stays on, but its topped off. got a feeling that the sensor is bad.
any thoughts?
where is the sensor if i haveta change it?
thanks J
any thoughts?
thanks J
I changed mine a few months ago. No biggie, but the replacement sensor is $$. GMpartsdirect has them cheaper, but they charge out the a$$ for shipping. Pass. side of the radiator. Drain the fluid to get below the sensor, unplug, remove, replace, refill, plug back in and your ready to go.
It's probably just dirty, they get crap on them and start acting up - pull it and clean it with rubbing alcohol and a rag and plug it back in. It will probably be fine and start working again (at least mine did).
If it's still setting the light after cleaning it I'd probably leave it unplugged too.
Cheers,
Bad30th
Cheers,
Bad30th
It most likely is the coolant sensor, but becareful because my low coolant sensor was on and since I had already had it fixed once by the dealership, I figured it was the sensor again. I ignored it and the next thing you know, my water pump broke and spilled fluid all over the parking lot at work. That same thing happened on my Bonneville, before I got my T/A, low coolant and then the water pump went.
