What fuel filter to use ????
I have a rock valley tank with in tank pump and aeromotive regulator on the front end. What kind of fuel filter can i use ? My engine is LS6 405hp. Question is there a OEM type filter wich would flow enough?
Originally Posted by MrDude_1
yes. you could use the TPI style filter if you have thoes connectors.
any of the V8 93+ Fbody filters would work too...
Okay! I found correct adapter fittings for 6AN at accel catalog.
