Need to be quieter...
Old 04-22-2005, 10:56 PM
VSGLS1's Avatar
Default Need to be quieter...
I have true duals with the mods in sig. 3" Sweet Thunders dumped at the axle is quite loud while at idle/cruising/WOT. They drone on the highway but offer good clearance. I am looking for good clearance and less drone around 2-3k. Did some searching, looking for info from anyone who has experienced anything that would fit my needs. Saw the Pro-Flows and Spiral Flows are usually a quieter option. I miss the sound of my Flowmasters, but don't miss the clearance issues...
Old 04-22-2005, 11:25 PM
Camaro99SS's Avatar
I don't have any experience with these, but you may consider trying a set of those silencer cones from Dynatech. I know Jegs sells them, and I'm sure Summit does too. I'd do that before switching mufflers, but if you insist, the Flo Pro Twisters would be your best bet.
Jason
Moderator
jimmyblue's Avatar
I think you want the exhaust exit out from under the
floor pan.
Old 04-22-2005, 11:57 PM
VSGLS1's Avatar
They dump after the rear seats. I have to look harder and see if I can get the pipes over the axles.
Old 04-23-2005, 02:05 AM
ls1mojo's Avatar
floor pan.
Yup. That is the definition of "Right". After inhaling exhaust fumes from a buddies dumped system for 10 minutes I called it quits.
A bit too much 'redneck cheap I can't afford a real exhaust' experiement to me, but you have to see it to believe it, words just don't cut it.
