ls1 power steering
Yes you can replace the rez. I did it on my f body pump you remove the pump then remove the bracket that holds the pump to the bracket. then tap off the steel brackets that slide on to hold the rez and pump togeather. you dont remove the pully. pull the rez. off and install in reverse.
((((((Administrator))))))
Try to find a part number on it and look it up on GMPartsDirect.com for about half the price then going to your local parts counter.
Peace,
Craig.
Peace,
Craig.
