dyno last week (readouts!!??) HELP
Help me, way lean, check dyno sheet.
my car is way lean, mods are in sig and I have the stock injectors and pump. I have a bigger pump now from TSP, but it did not come in before the dyno. Right 02 sensor was not working and is tuned by TSP (mail order). I trust no one around here to tune an ls1 so maile order is the only way unless I take a trip. The guy that dynoed my car kept calling it an lt1, I had to keep correcting him, just bothered me.
all readings were taken from 2000 rpm to 6000rpm at WOT
knock retard - 1.2 to 5.6 at WOT
injector pulse width - 12.6 to 17.2 at WOT
Air/fuel - 15 at 2000 rpm to 20.2 at 6000 rpm at WOT!! Idle - A/F is 14.1
timing - 38 to 28 degrees
Also, I forgot the Graph at his shop, but I'm picking it up Monday and I will post that. The graph is missing some info in the upper rpm, line dissapears then comes back, he told me that was the car miss firing?????
LS1TECH Sponsor
i'd talke to tsp and see what they say about it...did u get a scan of the run as far as KR, timing, rpm, ipw's, commanded a/f, blah blah blah...you might wanna post it if you do still want help from us...but mail tunes usually have to have a dyno readout to be able to fine tune the a/f mixture.
lata
Bill
lata
Bill
These are the only two charts I have. He was having trouble keeping the Air/Fuel meter on the end of my turndowns. But since then, I installed 02 bungs and installed Bosch 02's. U think I should go back down there w/ my new parts and my new fuel pump and have him dyno it again??? I also don't hear a header leak but u never know.
Maybe I will have check out his own equipment, see if there is an issue.
